Temp gauge feed?
Discussion in 'Mk2' started by PhilRyder, Dec 17, 2023.
  1. rubjonny
    yeah audi can be a bit weird on the wire colours, just go by pin positions :)
    PhilRyder likes this.
  2. PhilRyder
    Well, as it turns out we wasted a significant amount of time fitting a mk3 sensor and plug. We did it and it didn’t work, in fact it was worse. So I did what I should have done in the first place and check to see if there was a resistor fitted. I spoke to James and indeed there is. As a result it must be either the sensor now reading correctly or an air lock somewhere affecting the reading. New plug and sensor incoming. I haven’t sprung for a VW/Audi one as they are heinously expensive. We will try with the new one and go from there.
  3. rubjonny
    i would locate sensor and remove personally but up to you :)
  4. PhilRyder
    Do you mean resistor?
  5. rubjonny
    yes resistor sorry :lol:
  6. costel1969
    Sorry Phil, I couldn't help myself after reading this..
    daNpy and PhilRyder like this.
