and so it continues !! 1990 golf gti mk2 , temperature warning light keeps flicking on but the car isn’t overheating and not loosing water , also when the red light comes on my non working rev counter kicks into action until the light goes out , have cleaned earth on head brown /white wire and checked and cleaned obvious electrical connections , any idea what it could be in laymen’s terms as I far from being mechanical minded , thanks
its not a motometer clock set is it? if so, this might be why: https://clubgti.com/forums/index.php?threads/motometer-cluster-mfa-repair-fix-found.288785
Paul I might have a spare 140mph unit somewhere, but I need to sort thru my shed and the boxes of spare cluster parts see if I have enough to build a good set. If you send me your broken set that may work in your favour actually, I might be able to swap your PCB for a good one if thats the only fault. I definitely have several 8v main boards...
