Throttle bodies section index
Discussion in 'Throttle bodies & non-OEM ECUs' started by A.N. Other, Dec 8, 2009.
    Following on from the revival of GVK's 2-litre 16 engine sticky thread, here's a section index which we're going to trial in the TB section [:D]
    There is some crossover with the Carburettor section (inlet manifolds etc), so where relevant to TBs, links are also included, plus a bit besides.
    Parts source library
    Please add to this, if you have made good use of it. Thanks.
    http://www.clubgti.com/forum/showthread.php?t=202781
    The build threads
    (threads with loads of good stuff in them)
    smudge's 'Guide to Megasquirt ECU Throttle bodies ITB and EDIS'
    Toyotec's 'How to Megaquirt your ABF engine'
    Brookster's '2036cc 83.5mm 16V 45mm Jenvey's & MS1 V3 ECU '
    NigeP's Mk2 Golf ABF Megasquirt conversion
    Jolfa's guide to bike carbing your Dub
    vw_singh's ABF Megasquirt conversion
    There are plenty more!
    (thank you to everyone so far, please nominate your own or anyone else's threads for addition :thumbup: )
    Alphabetical index
    Air fuel ratio & AFR gauges
    (see Lamda / o2 sensors & Wide band)
    Air filters & boxes
    http://www.clubgti.com/forum/showthread.php?t=72956
    http://www.clubgti.com/forum/showthread.php?t=101700
    http://www.clubgti.com/forum/showthread.php?t=171153
    http://www.clubgti.com/forum/showthread.php?t=167065
    http://www.clubgti.com/forum/showthread.php?t=167016
    http://www.clubgti.com/forum/showthread.php?t=183475
    http://www.clubgti.com/forum/showthread.php?t=179087
    http://www.clubgti.com/forum/showthread.php?t=198404
    http://www.clubgti.com/forum/showthread.php?t=46410
    http://www.clubgti.com/forum/showthread.php?t=203138
    http://www.clubgti.com/forum/showpost.php?p=1715525&postcount=192
    http://www.clubgti.com/forum/showpo...om/forum/showpost.php?p=1715646&postcount=197
    http://www.clubgti.com/forum/showpost.php?p=1717171&postcount=205
    Air temperature sensor (aka Inlet Air Temperature, 'IAT')
    http://www.clubgti.com/forum/showthread.php?t=139922
    Alternators / brackets
    http://www.clubgti.com/forum/showthread.php?t=203924
    Base maps
    http://www.clubgti.com/forum/showthread.php?t=194183
    Cam position sensor
    http://www.clubgti.com/forum/showthread.php?t=175405
    http://www.clubgti.com/forum/showthread.php?t=184075
    Coil packs
    http://www.clubgti.com/forum/showthread.php?t=77576
    http://www.clubgti.com/forum/showthread.php?t=191253
    http://www.clubgti.com/forum/showthread.php?t=197067
    Crank position sensors, trigger wheels, wiring and brackets
    http://www.clubgti.com/forum/showthread.php?t=212842
    http://www.clubgti.com/forum/showthread.php?t=21129
    http://www.clubgti.com/forum/showth.../www.clubgti.com/forum/showthread.php?t=85890
    http://www.clubgti.com/forum/showthread.php?t=124732
    http://www.clubgti.com/forum/showthread.php?t=144182
    http://www.clubgti.com/forum/showthread.php?t=149776
    http://www.clubgti.com/forum/showthread.php?t=157240
    http://www.clubgti.com/forum/showthread.php?t=162887
    http://www.clubgti.com/forum/showthread.php?t=165703
    http://www.clubgti.com/forum/showthread.php?t=188476
    http://www.clubgti.com/forum/showpost.php?p=1800847&postcount=552
    http://www.clubgti.com/forum/showthread.php?t=202588
    http://www.clubgti.com/forum/showthread.php?t=202640
    http://www.clubgti.com/forum/showpost.php?p=1700510&postcount=99
    http://www.clubgti.com/forum/showpost.php?p=1741397&postcount=397
    http://www.clubgti.com/forum/showpost.php?p=1741728&postcount=406
    http://www.clubgti.com/forum/showpost.php?p=1742583&postcount=422
    http://www.clubgti.com/forum/showpost.php?p=1747119&postcount=442
    http://www.clubgti.com/forum/showthread.php?t=189912
    Dipstick position
    http://www.clubgti.com/forum/showthread.php?t=199246
    Distributor issues (eg fuel/spark only installs)
    http://www.clubgti.com/forum/showthread.php?t=139521
    http://www.clubgti.com/forum/showthread.php?t=191551
    Distributor blanking plates
    http://www.clubgti.com/forum/showthread.php?t=140478
    http://www.clubgti.com/forum/showthread.php?t=184185
    http://www.clubgti.com/forum/showpost.php?p=1822761&postcount=102
    http://www.clubgti.com/forum/showthread.php?t=227347
    ECUs
    Please use the search function if looking for specific ECUs
    EDIS
    http://www.clubgti.com/forum/showthread.php?t=48242
    http://www.clubgti.com/forum/showth.../www.clubgti.com/forum/showthread.php?t=84395
    http://www.clubgti.com/forum/showthread.php?t=85319
    http://www.clubgti.com/forum/showpost.php?p=1625617&postcount=2
    http://www.clubgti.com/forum/showthread.php?t=176335
    http://www.clubgti.com/forum/showthread.php?t=166663
    http://www.clubgti.com/forum/showthread.php?t=144201
    http://www.clubgti.com/forum/showthread.php?t=204894
    Emissions
    http://www.clubgti.com/forum/showthread.php?t=195015
    Excessive noise
    http://www.clubgti.com/forum/showthread.php?t=118153
    Fuel hose
    http://www.clubgti.com/forum/showthread.php?t=171932
    http://www.clubgti.com/forum/showthread.php?t=198024
    Fuel pressure
    http://www.clubgti.com/forum/showthread.php?t=80259
    http://www.clubgti.com/forum/showthread.php?t=64784
    http://www.clubgti.com/forum/showthread.php?t=125498
    http://www.clubgti.com/forum/showthread.php?t=163758
    http://www.clubgti.com/forum/showthread.php?t=168046
    http://www.clubgti.com/forum/showthread.php?t=200859
    http://www.clubgti.com/forum/showpost.php?p=1715469&postcount=191
    http://www.clubgti.com/forum/showpost.php?p=1721533&postcount=224
    Fuel pumps
    http://www.clubgti.com/forum/showthread.php?t=88888
    http://www.clubgti.com/forum/showthread.php?t=188642
    http://www.clubgti.com/forum/showthread.php?t=204853
    http://www.clubgti.com/forum/showthread.php?t=200930
    Fuel rails
    http://www.clubgti.com/forum/showthread.php?t=141116
    Haldex 4WD programming
    http://www.clubgti.com/forum/showthread.php?t=204511
    Idle
    http://www.clubgti.com/forum/showthread.php?t=126171
    Injectors
    http://www.clubgti.com/forum/showthread.php?t=60424
    http://www.clubgti.com/forum/showthread.php?t=81051
    http://www.clubgti.com/forum/showthread.php?t=149161
    http://www.clubgti.com/forum/showthread.php?t=141457
    http://www.clubgti.com/forum/showthread.php?t=168018
    http://www.clubgti.com/forum/showthread.php?t=174386
    http://www.clubgti.com/forum/showthread.php?t=181045
    http://www.clubgti.com/forum/showthread.php?t=194332
    Inlet diameter & length (including trumpets aka ram pipes)
    http://www.clubgti.com/forum/showthread.php?t=18403
    http://www.clubgti.com/forum/showthread.php?t=63950
    http://www.clubgti.com/forum/showthread.php?t=87599
    http://www.clubgti.com/forum/showthread.php?t=71821
    http://www.clubgti.com/forum/showthread.php?t=126335
    http://www.clubgti.com/forum/showthread.php?t=144869
    http://www.clubgti.com/forum/showthread.php?t=182847
    http://www.clubgti.com/forum/showthread.php?t=182576
    http://www.clubgti.com/forum/showthread.php?t=199052
    http://www.clubgti.com/forum/showthread.php?t=186823
    http://www.clubgti.com/forum/showthread.php?t=198875
    http://www.clubgti.com/forum/showthread.php?t=87039
    http://www.clubgti.com/forum/showthread.php?t=169630
    http://www.clubgti.com/forum/showthread.php?t=144693
    Inlet manifolds
    http://www.clubgti.com/forum/showthread.php?t=49209
    http://www.clubgti.com/forum/showthread.php?t=84146
    http://www.clubgti.com/forum/showthread.php?t=126607
    http://www.clubgti.com/forum/showthread.php?t=142582
    http://www.clubgti.com/forum/showthread.php?t=172141
    http://www.clubgti.com/forum/showthread.php?t=202343
    http://www.clubgti.com/forum/showthread.php?t=204098
    http://www.clubgti.com/forum/showthread.php?t=41272
    http://www.clubgti.com/forum/showthread.php?t=38078
    http://www.clubgti.com/forum/showthread.php?t=162631
    http://www.clubgti.com/forum/showthread.php?t=173184
    http://www.clubgti.com/forum/showthread.php?t=196392
    http://www.clubgti.com/forum/showthread.php?t=201558
    http://www.clubgti.com/forum/showthread.php?t=201958
    Lambda bosses & plugs
    http://www.clubgti.com/forum/showthread.php?t=60714
    http://www.clubgti.com/forum/showthread.php?t=74725
    Lambda / o2 sensors incl. AFR gauges
    (see also 'Wide band')
    http://www.clubgti.com/forum/showthread.php?t=155276
    http://www.clubgti.com/forum/showthread.php?t=171940
    http://www.clubgti.com/forum/showthread.php?t=164316
    http://www.clubgti.com/forum/showthread.php?t=173944
    http://www.clubgti.com/forum/showthread.php?t=192922
    http://www.clubgti.com/forum/showthread.php?t=159042
    http://www.clubgti.com/forum/showthread.php?t=187371
    Laptop comms & leads, serial cables etc
    http://www.clubgti.com/forum/showthread.php?t=88731
    http://www.clubgti.com/forum/showthread.php?t=126040
    http://www.clubgti.com/forum/showthread.php?t=132044
    http://www.clubgti.com/forum/showthread.php?t=180530
    http://www.clubgti.com/forum/showpost.php?p=1774168&postcount=511
    Mapping
    http://www.clubgti.com/forum/showthread.php?t=163105
    http://www.clubgti.com/forum/showthread.php?t=189678
    MPG
    http://www.clubgti.com/forum/showthread.php?t=195330
    http://www.clubgti.com/forum/showthread.php?t=162777
    http://www.clubgti.com/forum/showthread.php?t=195648
    Plugging injector holes
    http://www.clubgti.com/forum/showthread.php?t=3056
    http://www.clubgti.com/forum/showthread.php?t=151284
    Radiators
    http://www.clubgti.com/forum/showthread.php?t=153988
    http://www.clubgti.com/forum/showthread.php?t=144230
    http://www.clubgti.com/forum/showpost.php?p=1717551&postcount=210
    http://www.clubgti.com/forum/showthread.php?t=211040
    Ram pipes
    See Inlet diameter & length
    Rev counters
    http://www.clubgti.com/forum/showthread.php?t=159755
    http://www.clubgti.com/forum/showthread.php?t=166151
    http://www.clubgti.com/forum/showthread.php?t=179863
    http://www.clubgti.com/forum/showthread.php?t=173966
    Sensors
    http://www.clubgti.com/forum/showthread.php?t=144093
    Serial leads
    See Laptops
    Software
    http://www.clubgti.com/forum/showthread.php?t=10035
    Throttle cables
    http://www.clubgti.com/forum/showthread.php?t=152659
    http://www.clubgti.com/forum/showthread.php?t=202575
    http://www.clubgti.com/forum/showpost.php?p=1723118&postcount=244
    http://www.clubgti.com/forum/showpost.php?p=1729288&postcount=271
    Throttle position sensor/ aka throttle potentiometer ("pots")
    http://www.clubgti.com/forum/showthread.php?t=109790
    http://www.clubgti.com/forum/showthread.php?t=140481
    http://www.clubgti.com/forum/showthread.php?t=173906
    Throttle linkages
    http://www.clubgti.com/forum/showthread.php?t=83624
    http://www.clubgti.com/forum/showthread.php?t=195952
    Traction control
    http://www.clubgti.com/forum/showthread.php?t=86351
    Trigger wheel
    http://www.clubgti.com/forum/showthread.php?t=80078
    http://www.clubgti.com/forum/showthread.php?t=170390
    Trumpets
    Vacuum pipe (for brake servo and MAP sensor)
    http://www.clubgti.com/forum/showthread.php?t=36185
    http://www.clubgti.com/forum/showthread.php?t=86380
    http://www.clubgti.com/forum/showthread.php?t=152896rl]
    http://www.clubgti.com/forum/showthread.php?t=154034
    http://www.clubgti.com/forum/showthread.php?t=149032
    http://www.clubgti.com/forum/showthread.php?t=163213
    http://www.clubgti.com/forum/showthread.php?t=179665
    http://www.clubgti.com/forum/showpost.php?p=1719801&postcount=222
    Turbo-ing
    http://www.clubgti.com/forum/showthread.php?t=49352http://www.clubgti.com/forum/showthread.php?t=162224
    Wasted spark
    http://www.clubgti.com/forum/showthread.php?t=68778
    Water pipe outlet (16v)
    http://www.clubgti.com/forum/showthread.php?t=46398
    http://www.clubgti.com/forum/showthread.php?t=146507
    http://www.clubgti.com/forum/showthread.php?t=162047
    http://www.clubgti.com/forum/showthread.php?t=167644
    http://www.clubgti.com/forum/showthread.php?t=190939
    http://www.clubgti.com/forum/showthread.php?t=190458
    Wide band incl. AFR gauges
    (see also 'Lamda / o2 sensors')
    http://www.clubgti.com/forum/showthread.php?t=42602
    http://www.clubgti.com/forum/showthread.php?t=109141
    http://www.clubgti.com/forum/showthread.php?t=111547
    http://www.clubgti.com/forum/showthread.php?t=145027
    http://www.clubgti.com/forum/showthread.php?t=168766
    http://www.clubgti.com/forum/showthread.php?t=175373
    http://www.clubgti.com/forum/showthread.php?t=183972
    http://www.clubgti.com/forum/showthread.php?t=203766
    http://www.clubgti.com/forum/showpost.php?p=1733260&postcount=317
    Wiring looms
    http://www.clubgti.com/forum/showthread.php?t=68987
    http://www.clubgti.com/forum/showthread.php?t=72967
    http://www.clubgti.com/forum/showthread.php?t=109211
    http://www.clubgti.com/forum/showthread.php?t=176890
    http://www.clubgti.com/forum/showthread.php?t=191774
    http://www.clubgti.com/forum/showthread.php?t=195461
    Nominate threads for this index !
    Please don't post technical questions on this thread, but if you have seen any thread anywhere on the forum which ought to be included, to help make this a better resource for everyone, please post a link below and the moderators will add it to the index :thumbup:
    Your help is much appreciated, and makes this a great reference source!
  4. altern8 Forum Junkie
    Cocos (Keeling) Islands
