Hi, I'm needing some help wiring a aum loom to a auc throttle pedal. If anyone could help it would be much appreciated. Thanks
loads of info here: https://www.clubgti.com/forums/index.php?threads/lupo-auc-to-1-8t-awu-wiring-help.287937/ early mk4/a3/tt had remote pedal actuator same as the polo/lupo so if you end up with the mk4 bluer plug behind the bulkhead you can source the loom between this plug and your pedal actuator for direct fit. otherwise, ECU pin -> Early MK4/Polo/Ibiza Cupra remote pedal actuator: 33-4 34-6 35-1 36-3 72-5 73-2
I went and got a mk4 petrol pedal at the weekend and seem to have done the trick. Been following your thread on the wiring. Thanks for the help
