Hi, 1.6 engine (EG prefix) Starting from cold the engine ticks over quite quickly After a short while is slows down to around 900/1000 rpm. That is ok. Its a bit 'lumpy' but as the car and engine have only done about 40 miles since 2011 that may improve with use. When the engine is really warn the tick-over slows right down to a speed that regularly causes the engine to stall. How should I go about setting it up correctly? Thank you.
