Hi does anyone have a manual for this or does anyone know how to programme a new keyfob? Any help would be great thanks Dave
here is the programming sequence turn the ignition on enter the first digit of your pin by pressing the override button the appropriate amount of times turn the ignition off then on again enter the 2nd digit of your pin by pressing the override button the appropriate number of times turn the ignition off then on (the system should chirp twice) press button 1 of your remote (the system will chirp once) turn off the ignition (system will exit programming after 10 seconds) if you send me your e mail i will send you the whole manual
Toad A101 Hi. Would there be any chance that you could send me a copy of the same manual. Please and thank you.
