heres one for a resident toad fitter, could someone please give me the steps to take to delete a lost key from the system? i am getting quite paranoid about having a set of keys on the loose and a car that can be pinched! also if anyone has an old key fob to pass on i will gladly part with beer tokens so i can get 2 working sets of car keys again. cheers x
According to the manual..... Code: Code Software Switch Function Default LED On LED Off Setting Setting 3-3 Erase OTHER transmitter Codes (Save code of - On On Remote Being Used) Together Together To adjust switch 3-3 Erase OTHER transmitter codes Complete the PIN code entry sequence and: Turn the ignition on…..Press button 1 three times and the Led will turn Amber to show any switches starting with the digit 3…..Turn the ignition Off and On….Press button 1, 3 times the siren will chirp each time the button is pressed…..You are now in switch 3-3…..Press both buttons on the remote to toggle the switch from Off to On or On to Off (both need to be ON in this case) After adjustment, switch the ignition off and wait for the system to exit programme mode indicated by a double chirp of the siren or turn the ignition back On to adjust any other switches. ^^ Best check those instructions before breaking your alarm
thanks muchly, i will take you up on the offer of the key fob too, will pm you when i am home also will update if the sequence works...
