Top suspension nut
Discussion in 'Tools, Equipment & Fasteners' started by Cazzzooom, Nov 11, 2006.
  1. Cazzzooom Forum Member
    Don't locking nuts have a nylon thread?
    Mine doesn't have any
  2. vw_stu Forum Member
    Wilstead, Bedfordshire / Coventry
    might be an idea to nip and get some nylocks then matey, might be expensive if the suspension came loose [:s]
  3. benlg81 Forum Member
    so it could be my top nut thats the problem i'll see how it looks
    not always no, the vw ones are just slightly pinched or something?
  5. vduben Forum Member
    melton, leics
    neanderthol man:p
  6. keith_lemon
    keith_lemon Forum Member
    on the edge.... also north wales, close to rhyl
    i`ll add an old socket from my sealey set..... i dont abuse my good tools :lol: :lol: [:D]
  7. mk2monster
    mk2monster Forum Member
    Portsmouth
    i had this prob a month ago i welded a short bar onto a socket, then u can get the allen key through! worked a treat!!
  8. vduben Forum Member
    melton, leics
    thats a diesel inj tool:)
    thats what i ended up doing, its the best cheapest way!!
  9. g60racing New Member
    This is what I used, no welding required... Box wrench from tool shop for a few quid then a spanner to go over the top. Easy..
    box wrech is basically metal tube thats been shapped, so its hollow even though it looks black in the photo
  10. Cazzzooom Forum Member
    Cool! vdubman, where did you get that?
  11. pascal77uk Paid Member Paid Member
    Chelt
    i use a drop nose ring spanner and allan key
  12. H5LRW Forum Member
    Cheshire/Norfolk
    I've used an allen key and spark plug socket before, put the allen key through the centre of the plug socket, socket onto the nut and crack with a spanner.
    Nothing works aswell as an impact gun though!
  13. Cazzzooom Forum Member
    FINALLY! I've done the Job! In the end I used 2 sockets, a strip of rubber, mole grips, an adjustable spanner, allen key socket, wrench of course and the special top nut keys that I bought from GSF!
    I'm well chuffed and now I can have some knockless and squeakyless driving![:*:]
    Thanks for all the help people!:clap:
  14. Nordoff Forum Junkie
    Stoke On Trent
    Similar to that, cut a box wrench and welded a handle on.
    Reason was some stuff like koni struts you need to get a socket on the top of the strut to stop it turning.
    This shows it takes up to a 15mm socket in the middle, plenty big enough.
  15. Matt82
    Matt82 Forum Addict
    GTI Scene
    the top nut came off one guys here dead easy with a Clarke 12v impact wrench even after he had rounded it to buggery.
  16. Jacob New Member
    power to tighten
    How do you now when the nut is nice and tight.My top mount have a little bearing that fits underneath the mount.If it's to tight it might afect the steering.Any advice......[:s]
