Toyotec presents...the effect of ITBs on a bone stock 16V 29/11/11
Discussion in '16-valve' started by Toyotec, Nov 29, 2011.
Tags:
  1. Toyotec
    "Short engine" as in 'complete bottom end'.
    Still a std ABF job.
  2. G28OPN Forum Member
    Northamptonshire
    Ah, guess I was thinking of short block then lol
  3. jmsheahan CGTI Graphics Designer
    Wiltshire
    Interesting reading, the call for SEM is getting stronger if I can get my head around it. Will be keeping an eye out for updates.
    (head kind of hurts now though lol)
  4. Toyotec
    It is great when you run a SEM system, as you can make drastic changes to the hardware, such as from a plenum to an ITB set up or from NASP to Turbo and the controller can be made to "know" via some config settings and a map.
    Just need a window of time to get the car all prep'd to support the ITB hardware as well as make it easily reversible, as I wish to continue tracking it with the plenum set up for now :thumbup:
  5. KeithMac Forum Junkie
    Kazakhstan
    Interested to know how stable the afr is compared to speed density and a single throttle plate?. Do you use soley alpha-n for tuning?.
    Quite a few use blended alpha-n due to different in gear loads, do you think it's worth the extra effort?.
  6. Ben S
    Ben S Forum Junkie
    Essex
    This one was pretty good especially for a the limited time it was on the vehicle, good initial tune one evening by Eddie and then some refinement from me the following evening.
    If you need a slight correction here and there the UEGO could handle it with a low authority, few percent etc. There is also the coolant/ IAT air density correction which can correct anything else.
  7. KeithMac Forum Junkie
    Kazakhstan
    Sounds good!.
  8. Toyotec
    Hey, Keith.
    The airflow in a non plenum NASP system is pretty much dependant on atmospheric conditions or altitude.
    So when opening the throttle for a given ambient condition speed and load, you will pretty much have the same amount of air being processed by the engine. As result a mapped injection duration for a given speed and throttle angle tends to give repeatable exhaust lambda readings.
    Also as you are not filling and emptying the air charge as in a plenum, with ITBs your idle tends to be more stable, right down to 600 rpm! (all other settings being robust of course)
  9. KeithMac Forum Junkie
    Kazakhstan
    Think I will have a crack at this then when I recommission the Mk2 :-). Always fancied a car on ITB's!.
    Good work and a good informative thread, cheers ;).
    Toyotec likes this.
  10. Toyotec
    Testing on the Toyotecwerke ITB 45s recommenced today with a trial and run up on JENVEE.
    You can find that update >>here<<
    :thumbup:
  11. Coldforged Forum Member
    Manchester
    I would especially like to have some detailed pictures, as I guess I have most of the parts kicking about as well and would give me an incentive to get the old girl to another track day.
    Toyotec likes this.
  12. Toyotec
    I had material to compile into a post that I am happy to share.
    Had a look today for the pictures and have to do a bit more digging.
    I have quite a few that I took at several stages.
    Coldforged likes this.
  13. Coldforged Forum Member
    Manchester
    Any luck toyotec?
  14. Toyotec
    Yes.
    I found most of my pictures on this.
    Will get something up soon [:D].
  15. Tristan
    Nicely updated, Ed.
  16. Coldforged Forum Member
    Manchester
    Brilliant thank you Ed. I am just slowly rooting through my parts gathering everything now.
  17. Toyotec
    The new thread for it is here.
