Before I re-invent the wheel has anyone on here fitted a TPS sensor to a G60 throttle body?. I'm thinking it may need a custom shaft machining to drive the sensor?. Any input appreciated. Thanks, Keith.
L shape bracket is what was done back in the day. Alternatively, I found an Audi motronic throttle body with a 3 pin TPS for one of my old 8vs I fitted MS to.
Cheers, did that involve a linkage?. It has to be the G60 TB as it has the air bypass butterfly for off boost driving.
I've not made any inroads yet, I use the G60 switch so have 3 states, Idle Partial and Full throttle. I wanted TPS for acceleration enrichment really but have been using MAP based enrichment. Still on the to-do list!. Really want a direct drive from the throttle shaft but haven't got a lot of room under the G60 throttle body.
