Tsr 1.9 8v
Discussion in 'TSR Performance' started by Leigh ivison, May 5, 2021.
  1. Leigh ivison New Member
    Hello does anyone know much about these engines I’m the the process of buying a used one it’s the 1.9 8v with the c pack head and 202 cam.
    What sort of powe can i expect?
    Is the block a bored out 1.8?
  2. PhilRyder
    If you call TSR they are very helpful.
    cupracraig likes this.
  3. Leigh ivison New Member
    Ok thanks wasn’t sure if they would be interested in answering questions
  4. dodgy
    Is it old tsr, or think there has been 2 incarnations since. Possibly retro resus as think guy used to work at tsr?
  5. Tristan
    Iirc they were a 1.8 block with a 2.0 crank.
    Leigh ivison likes this.
  6. Leigh ivison New Member
    I think it’s a few years old
  7. Leigh ivison New Member
    Oh right i didn’t know that thought it would be a 1.8 bored out,so how does that make a 1.9?
  8. Tristan
    81mm bore, as a 1.8 has, with the 92.8mm stroke that a 2.0 crank gives (86.4 on a 1.8) , equals 1915cc.
    You'd have to bore a 1.8 to borderline unreliable levels, some thing like 83 or 83.5mm to get anywhere close to 1.9. Which requires special machining equipment, and custom (expensive) pistons.
    Whereas with some clearancing in the block, standard pistons, rods and crank, albeit a mix and match of 1.8 and 2.0 parts, would give a "1900".
    However, I'd much prefer a standard 2.0 bottom end lol.
  9. Leigh ivison New Member
    Thanks for that info,yes I’d probably prefer a 2.0 bottom end,it was the head i really wanted as it’s ported,bigger valves and a cam,but the bottom end is supposed to have forged pistons uprated bearings and arp bolts
  10. Tristan
    I bought a tsr 1.8 a few years ago, and put the head onto a 2.0 bottom end, myself, for my own mk2.
  11. Leigh ivison New Member
    That’s sounds a good idea which head and cam did you have?
  12. Tristan
    Same as yours.
  13. Leigh ivison New Member
    I bet it went well do you still have it? Did the driving characteristics change much with the tsr head and cam?
  14. Tristan
    Tbh, no, didn't change an awful lot. It's a wee bit torquey-er, and pulls better at the top end, but if I was doing it all over again I'd just go 16v.
    Yes I still have it, i dailied it for a couple of years, and went to the Ring twice, Spa, and a local trackday.
  15. Leigh ivison New Member
    I do like the 8v especially with a 2ltr bottom end but i do wonder about a 2ltr 16v (abf block and kr head)
    valvemiester likes this.
