tsr 1900 bore kit
Discussion in 'TSR Performance' started by nme motorsport, Oct 19, 2009.
  1. nme motorsport Forum Member
    whats included in the tsr 1900 rebuild kit i have an engine with some reciepts which include the mentioned kit but didnt list the parts supplied with the exception of the metal headgasket and headbolts and how could i tell if the paper works matches the engine if i remove the sump would there be anyway of telling the parts from a standard 1.8 to a 1.9 are the b/e bearing caps different in size or not thanks
  2. Mike_H Forum Addict
    The big holes up the middle of the engine are bigger... normally 83mm vs 81mm standard.
  3. skint_golfer
    skint_golfer Forum Member
    Banbury
  4. challice Forum Member
    wiltshire
    :thumbup:
