TSR bigger brake kits
Discussion in 'Chassis' started by wussel, Nov 11, 2003.
  1. wussel Forum Member
    I am going to increase the size of my mk2 16v brakes. It is a 1989 model, so it has the bigger 256mm brakes already and I want to fit brakes without changing the wheels (15 inch TSW Stealths)
    TSR do a 285mm kit, calipers extention brackets, Pagid pads, and the bigger black diamond disks, for 279. That sounds like a good deal to me. Has anyone fitted this kit? Is it reasonable quality? Are they getting confused with the mk1 285mm kit?
    I have phoned around quite a bit seeing what other firms are offering. C+R want 195, then you have to buy the pads and disks on top of that. VW sel the proper brand new G60 caliper extensions for 100 each!! And AutoTechnik say I would be best finding some in a scrapyard. I can't find ay localy to me, which is how I ended up ringing TSR.
    I know a lot of you don't like TSR, bu I have always found them to be alright, if a bit on the expensive side.
    So what do you think?
    I would personally go for a G60 280mm set up, for ease and price. The discs are cheap as.
    Someone must have some for sale - try wanted ads on PVW.
    Chris
  3. jamesa Forum Junkie
    Abz
    1991 16v
    Front - Black Diamond grooved discs with Mintex 1144 pads - standard size & calipers
    Rear - kept standard discs with Mintex 1144 pads
    .....Excellent
    1982 8v
    TSR 270mm BB kit works fine..........worth the money
  4. GVK
    wussel, try 'andrew ensom' on PVW forum, i'm sure he sells the new G60 caliper extensions a lot cheaper than VAG
    Get your caliper sliders machined as per my big brake pageand use 16v fitment (16.3mm) pads and 280mm G60 discs...
    Ate power discs from ECP are about 70
    Edited by: G_V_K
  5. dUff
    dUff Administrator Admin
    Everybody Offline - looking good
    I got mine from a Seat Ibiza Cupra owner who was upgrading, the Cupra has the same setup as the G60 and are red power coated.
    It Could be worth putting a advert on a Seat forum to see if anyone has a second hand set. As a common upgrade is to fit the new Cupra R setup Brembo`s from the dealer for about 350 notes ( these required 17" wheels)
  6. wussel Forum Member
    Thanks for the replies. Gary, I have tried Andrew Ensom, but he dosn't do them anymore, he only deals in new parts, like disks and pads.
  7. prof Forum Addict
    Suffragette City
    check the classifieds on here and pvw also on seat sites
    ibiza cupra 20vts and late 16vs had 280/g60 setups
  8. wussel Forum Member
    Right then I have sourced a couple of Ibiza Cupra owners who are doing the Brembo upgrade soon. How much do you reckon their standard front brakes are worth?
    Also is there a specific model or year when they were fitted with the G60 style brakes?
  9. prof Forum Addict
    Suffragette City
    no ibiza cupra should all be 20vt= g60
    I have Badger bills old ones on mine,
  10. prof Forum Addict
    Suffragette City
    new ATE grooved discs from eurocarparts are also a good move.
  11. jason Forum Member
    all cupra's have 280's
    all 2ltr 16v have them too(ibiza and cordoba)
    all 2ltr 8v and 1.816v use 256x20mm ;)
  12. wussel Forum Member
    Thanks for that. Least now I know I won't be wasting their time.
  13. Admin Guest
    Awesome Gti also do an 280 kit:
    new German made 280mm discs and Pagid pads
    2nd hand servo & master cylinder
    calipers, caliper carriers
    hub carriers and bottom ball joints. 450 notes. :)
  14. Peter Forum Member
    Moderators please feel free to delete my post if it is classified as advertising.
    I purchased my G60 calliper Carriers off a chap called Philip Walker who used to post on the old forum. They actually came off a Audi Quattro but they are the same as G60 280 spec. I paid around sixty pound for two. You should be able to contact him at
    sales@pwmotorsport.
    Hope this helps
    Pete
  15. fthaimike Forum Addict
    Im running the Blackdiamond 285mm combi discs from TSR with braided hoses & 16v supply and i cant fault these. (saved my car a good few times).
    Edited by: fthaimike
  16. swax Forum Member
    Bermuda
    What Size are they in a standard Mk3 8 Valve??
    I had ATE Power Disks on my previous GL and they were awesome but very small!!
  17. prof Forum Addict
    Suffragette City
    mk3 8valve, 280 on the pre 96 288s after that
    288s are pretty good, huge pad area
