tsr exhaust manifold
Discussion in '16-valve' started by gixerben, Oct 2, 2005.
  1. gixerben Forum Member
    Hi all, just purchased a TSR exhaust manifold of ebay for my mk2 16volt,need some info on which system to match it up to. has the manifold a flange fitting??? anybody got a tsr manifold, any help would be great:)
  2. gixerben Forum Member
  3. Goldie Forum Member
    I have one of these. They mate up to a standard system as the
    bore is the same.
  4. gixerben Forum Member
    Thanks but wanted to change the system as the standard one has reached the end of it life. Does your manifold have a flange fitting or is it a slip on??
  5. GVK
    Should be a flexy joint that then mates to a slip on fitting for the standard system as part of the manifold
  6. gixerben Forum Member
    This is a picture of manifold so you can see my problem[​IMG]
  7. gixerben Forum Member
    Fingers crossed that this is not the only thing that comes in the post then..:)
  8. recardo Banned
    yeah you should have an extra bit.....also its valve not volt ;)
  9. gixerben Forum Member
    Doh!!!!!:lol:volts away...
  10. JEZ
    Jez Forum Member
    You're missing the second half of the flexi joint in your pic.
    This a TSR 8v item, but I imagine it's pretty similar.
  11. nando Forum Member
    yeah looks like that, give tsr a bell they could sell you just that end part.
  12. gixerben Forum Member
    Thanks all, bl00dy thing hasnt turned up yet so dont know what he gonna send. [:^(]looks like i may be on the phone to TSR to buy the rest of it. should have just got a new one....
  13. Mike_H Forum Addict
    That's not the standard end pipe is it? The welding's not the best...
