Twin 40s / 45s - what fuel pressure?
Discussion in 'Carburettor' started by mr.brown, Apr 27, 2007.
  1. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
    Thanks for the responses re the return line (or lack of) in the other thread. It raised another question - namely that of running the correct fuel pressure.
    I'd be grateful if you could give me an idea of what psi you're running and with what engine/carbs.
    Thanks again.
  2. GVK
    Carbs use only 3-5psi usually
  3. Hotgolf
    Smelly Cornelly
    Yeah, think I'm running 5 psi.
    2.1 16v, twin 45's/ 185 main jet 165 idle( i think)
  4. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    3.5 psi, more than enuff normally, thats all I run on my 8v with 48's, but the carb size is largely irelevant
  5. 3hirty8ight Forum Member
    3.5 over here..
    Would it matter if you ran it high if you had a return?
  6. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    They just dont need any higher pressure's than above really, just enough to keep the fuel bowls topped up but not too much to cause flooding.
