Twin Bosch 044 Fuel Pumps Plumbing
Discussion in 'Turbocharged, Supercharged or Nitrous !' started by sambo, Feb 13, 2011.
  1. sambo Paid Member Paid Member
    Can anyone please offer some input on plumbing high pressure side when running 2x044 pumps?
    Found a kit in Usa 034 Motorsport at 50 or so but its pricey once postage and duty paid, over here its upwards of 130 for a twin pump rail and couple of banjo bolts!
    Am i right in thinking it will work out cheaper and just as good to use some 13mm ID braided fuel hose with necessery AN fittings?
    I am sure hose and AN fittings can be bought for less then 50?
    Any input welcome:)
  2. Rallye_Will Forum Member
    Devon
    Aeroquip fittings are very expensive, example 90 degree bends are circa 15 each so probably not less than 50
  3. sambo Paid Member Paid Member
    Fair point, i need 4 fittings. However other makes on market nearly as high quality at half price
    Any pics anyone?
  4. Rallye_Will Forum Member
    Devon
    You say that, but I used some other types and they were poor quality tbh.
    I too am interested in the dual pump setup, I would have thought it would have been fine to install it as you mention in your first post
  5. rubjonny
    are you running this on k-jet or electronic injection? if EFI you can get suitable banjo fittings with barbed ends from ebay cheaply, just need a single outlet one and a duel outlet, plumbed together with some proper fuel injection hose.
  6. badger5
    nr Glos
    Y piece is what I use on ibiza
    my -8 and -6 fittings cost a small fortune
    speedflow fittings
  7. rubjonny
  8. sambo Paid Member Paid Member
    Are you on -8 size main feed between pumps and fuel rails Bill or -6?
  9. sambo Paid Member Paid Member
    Its for EFI. Just to clarify its for high pressure outlet side of pumps in case there is cofusion
  10. rubjonny
    cool, the above linkies should do you fine then, just make sure you use proper fuel line clips :thumbup:
  11. sambo Paid Member Paid Member
    Cheers John, it seems like a cheaper alternative! I'v just been on the phone to Speedflow and gota price for fittings required..... 148 delivered! Bit pricey that i'd say
  12. rubjonny
    aye if it was k-jet pressures then yeah you want to spend the extra. but efi runs at much lower pressures so boggo push fit stuff is just fine :thumbup:
  13. sambo Paid Member Paid Member
    Come to think of it there will be fair amount of pressure
    As its a raising rate fuel pressure regulator and i will be running 3.5-4 Bar static pressure with boost i may see up to 6 Bar!
    Thats K-jet teritory
  14. badger5
    nr Glos
    -8 feed, -6 return to swirl pot
  15. g-dub Forum Member
    not got a pic to hand but try earls for the fixings, i had to get the Y piece from USA, only place i could find it, i ordered it from Summit,
  16. sparrow Paid Member Paid Member
    Leamington Spa
    There's an Earls at Silverstone, I used them for my car. www.earls.co.uk.
    Silverstone - 01327 858221.
    They also have a branch in Devon according to my invoice.
  17. sambo Paid Member Paid Member
    Thanks lads i will try them
  18. badger5
    nr Glos
    my Y piece came from speedflow in bristol
  19. sambo Paid Member Paid Member
    Earls quoted me around 80 today, not to bad i thought!
  20. Dave
    Sligo, Eire
    Find me some 18mm ( or 16mm) double banjos?
    Firstly. Why is this thread in "Turbocharged, Supercharge and Nitro"? As it equally applies to K-Jet, ITBs and Carbs!
    Easy to find lots of 12mm double banjos!
    But find me some 18mm doubles for the input end!?!?
    I have a design using 16mm doubles opened out, but these are also hard to find
    The second pump is just a basic 044 back-up!;)
    This is the design using solder fittings, but even the manufacturers, SIHN, don't have any in the factory.
    They wil make me 1000 though![:D]
