twin tank mk3 tdi set up...54mpg on wvo
Discussion in 'Diesel' started by LregG, Feb 7, 2012.
  1. Dubnutter Forum Member
    If brookster still has his old twin tank setup i may take a punt at that at some point
  2. LregG
    LregG Paid Member Paid Member
    I've got that...its going on my Audi A3 tdi
    Mike will say its not a good idea to use evry with a chip I'm sure
  3. Dubnutter Forum Member
    Probebly, if thats the case then so be it. I can still get a decent kick out of the meth injection.
  4. Dubnutter Forum Member
    Like the wheels lreg, matches the car well me thinks.
  5. LregG
    Anniversary'ish
  6. Dubnutter Forum Member
    I had an anni' mk3 gti, they do look similar. I was told they were splits. Not sure if they were or just fake bolts.
  7. LregG
    I've just driven past three petrol stations and all of them had big ques of panick buyers...luckily, I have 100lites/75 of rapeseed oil left [8D]
  8. geeteethree Forum Member
    preparations are in effect at the GT3 compound to safeguard my veg oil stash
  9. Dubnutter Forum Member
  10. LregG
    I like it, maybe I should take some precautions for my liquid gold lol
  11. Dubnutter Forum Member
    Im going duel fuel with the svo twin tank setup. Love what lreg and brookster has done. Im afraid im going to have to copy you.
  12. LregG
    Crack on mate...no time like the present!
  13. Brookster
    Due to the world Fuel shortage i've been running the Fabia 1.4TDI PD on a 50/50 mix with the weather being warm :thumbup:
    Runs Quieter and just as good but will run 100% Derv next fill and then 50/50mix so i don't strain the pump too much ;)
    RR Day at Chipwizards on Saturday so will see what the Turbo Veg Wagon is pushing out
  14. Brookster
    [youtube]GOFbsaNeZps[/youtube]
    [youtube]QEX1YFXYTdI[/youtube]
  15. Dubnutter Forum Member
    Im a bit confused, i understand titration makes wvo ph neutral, so untreated wvo is quite acidy. Does this mean you can run filtered wvo untreated aslong as you upgrade seals etc. so treated wvo does not need seal changes etc.
    Have i got that right?
    I have found a supplier of wvo, but i dont want to store all the chemicals for titration, and tbh the pump would benifit a rebuild anyway.
  16. LregG
    My plan is to run my pump until the seals go and then fit viton seals...As a general rule of thumb, Bosch seal kits contain black seals (viton) and green (non viton)...the rear seal (injector pipe head end) isn't viton but is available in viton but not through Bosch and only from the states, I've yet to find the pulley end seal in viton
    I have a viton fuel return pipe set, viton seals and a new front seal and the triangular bolt tool ready for rebuild time as and when they start to leak.
    So, to answer your question, either worry about your acidity levels and adjust it or replace seals as and when they leak...the other option is a dieselbob pump rebuild to veg spec as brookster has done.
    Don't forget, the twin tank system flushes the veg oil out of the pump and lines before shutting the car off so realistically the acidic issue is only during driving on veg, at no point is the pump sat with veg oil in
  17. Dubnutter Forum Member
    Ah i see. Mind you, for 250 quid for a rebuild to veg spec, on a pump thats done over 200k maybe a good idea anyway.
    I have been researching automated controllers, seems fairly simple to build one.
  18. LregG
    Automated twin tank controller???
    It's no issue controlling it yourself, It's second nature now, in fact, when I drive the Audi, I reach for the wvo switch that isn't there lol
  19. Brookster
    i don't use WVO anymore but i used to make make own , just use SVO now straight into the tank
    [youtube]SsZQ-cPziJA[/youtube]
    [youtube]0KAqE0XVKrQ[/youtube]
  20. Dubnutter Forum Member
    Lol fair point. Maybe just a series of feedback led's so i can see any faults etc. and a 555 timer or turbo timer to purge the system at idle while the car can be locked up and left.
