hi. when i put together my 2.0l 16v engine, i thought i was using KR cams, but after reading a few posts on here, im not so sure. the exhasut cam has a dot on the timing wheel, as per most 16v exhaust cams. but my inlet cam had a line on the timing wheel, which is different to have i have seen on a few pictures posted. im not with the car at the moment so i cant get any part numbers, so i was wondering if the KR inlet cam also came with small line indentations to set up inter cam timing. if i remember correctly, the cams im using came from a left hand drive mk2 16v, running KE-jetronic.
