VAG-Com ABF Digifant label files
Discussion in '16-valve' started by G60Dub, Sep 18, 2009.
  1. rubjonny
    right click the vagcom shortcut and click 'open file location' it should take you straight to the vagcom folder. or if its 64bit os look in program files (x86)
    thaty code is telling you the hall sensor in the dizzy is not working, either due to hall sensor failure or the wiring to it is damaged
  2. slarner New Member
    Hi guys sorry to pull up and old thread.
    How can i download the label files having issues with my mk2 ABF. I keep getting you do not have permission to download the file!
    Stewart
  3. rubjonny
    hello there, its becasue you are a new user. once you've posted a bit more you'll be able to download attachments :)
  4. Gman2oo6 New Member
    Netherlands
    Ahh thats what i have to lol well ok then i will post some more :)
    shaunsgolf31313 likes this.
  5. Sándor Tamás New Member
    ...this is also the problem with me... :)
  6. lasycat New Member
    have same problem/
  7. Ixso88 Paid Member Paid Member
    Hi, do you know why i don't have the permission to download?
  8. rubjonny
    you'll need to make a few more posts to get out of the 'new member' zone to download non-image attachments :)
  9. okops New Member
    Hi,
    could you please advise if the label files in the extraction are applicable for ECU with the following part number:
    037 906 024 AB / no immo?
    I think that this one is 3.0 Digifant?
  10. rubjonny
    no these label files only work for digifant 3.1 and 3.2 ECU, I have made a 3.0 label file but not had the chance to test it as of yet. drop me a PM and I'll forward it on so you can give it a try :)
  11. Pavel zhyhalka New Member
    Hello , I can't download file. Can you send mail on
    Novanolive94@gmail.com
    Or how many post need to make?
  12. rubjonny
    Pretty sure you need 10 posts then you can download files :)
  13. rubjonny
    I've added my DF 3.0 label file to the archive now its been tested and confirmed to work :thumbup:
    G60Dub likes this.
  14. Gman2oo6 New Member
    Netherlands
    ok so i have to post some more to get this label file for my digifrant 3.0
    right then i will do that
  15. Gman2oo6 New Member
    Netherlands
    Lol don't know who said it was working for the 3.0 digi but that's not true
    ( volt 23.4 / engine off rpm 328 / also in top corner when you go into measurement it gives a FAIl REDIR LABEL )
    i will upload some pictures tomorrow ( using VCDS 15.7.1 )
    but thanks anyway mate !
  16. rubjonny
    ah I see the problem, 037-906-024-AG.lbl should be called 037-906-024-AB.lbl, or maybe 037-906-024-G.lbl if you have one of the rare very early ones.
    I was working on a proper redirect file for it but I haven't got round to finishing as there are a load more part numbers than the 3 included and its more efficient to have a redirector to point at 3 files rather than have one for every single possible part number
  17. Gman2oo6 New Member
    Netherlands
    [:D] Ok will try it tomorrow ( better jet in 8 hours ) will let you know !
  18. Gman2oo6 New Member
    Netherlands
    it works but still not ok
  19. rubjonny
    looks fine to me, whats the issue? can see ignition timing is too long to fit easy fix but the rest seem to be identified properly
  20. Gman2oo6 New Member
    Netherlands
    hmmm could you explain to me why every 5 sec my temp moves from realtime temp to +120 C ?
    Or is my ECU goin bad ? he also does it with the voltage from 14.1V to 24 V
