Vagcom / VCDS / Fault code reader. Help.
Discussion in 'Vagcom / VCDS' started by Teddy, Apr 21, 2012.
  1. Teddy
    Teddy CGTI Regional Host
    Northampton
    All, just after some advice.
    I have bought a fault code reader which works fine.
    However, I've just bought a netbook, and thought Vagcom might be a good idea.
    However, I'm a little confused.
    What is the difference between Vagcom and VCDS?
    All I really want us to be able to read off fault codes, and my fault code reader is really basic.
    It would be a "nice to have" to be able to activate options on my car etc...
    What do I need?!
  2. tshirt2k
    tshirt2k Forum Junkie
    Herts
    It's the same but they called it vcds after version 804.2. It stands for VagCom Diagnostic Software.
    You don't always need to get a full version. A clone can work just as well but not necessarily the early versions without CAN.
  3. Teddy
    Northampton
    That explains it nicely. Thanking you.
    Are there actually any good eBay items?
  4. tshirt2k
    Herts
    Don't think 409 version is worth getting.
  5. Teddy
    Northampton
    Best buy would be?
  6. MUSHY 16V
    aberdeen
  7. Collie Forum Junkie
    Adlington Lancs
    what car do you want to use it on>?
  8. Teddy
    Northampton
    My Bora pd130.
  9. tshirt2k
    Herts
    That 10.6 is future proof if you decide to go for a newer car that uses CAN. That's around the goin rate but 11.3 versions are around now.
    Those are dear on eBay I can get them cheaper than that.
  10. turbotommy Forum Member
    Newcastle upon tyne
  11. MUSHY 16V
    aberdeen
    i'v had mine a few years now used it on a lot of newer cars
    dont think i would pay 60 to 70 quid the ebay ones are selling for
    out of intrest how much can you get them for
    i payed 34 for the one i have
  12. rubjonny
    a 10 usb cable is fine for older cars including reading fault codes on mk4 golf, but if you want newer cars and/or can-bus stuff you need an expensive pro/full vcds cable.
    the 10 cables work with vag-com 409 and vcds-lite as above they're the same thing just vcds-lite is a newer version which works on 7/64bit os. trouble is you need to make sure the cable you get has 7/64bit drivers as not all of them do
