Having never seen or used either i thought i would ask some questions, thanking you please.... Where's the best place to get the software and lead from and how much is the licence to use it? What's the difference between vagcom and vcds?
officially from http://www.ross-tech.com/products.html but I don't think everyone has legit copies, there are compatible* leads on eBaY and possibly even CDs with old level software on
As above, you just buy it online from the Ross-Tech site. You download it and then make payment for full registration, and get the registration key by email. I got VCDS-Lite which was about 60. I'm using both an eBay dongle and also one I made myself. If you buy it, be sure to install and register it on a laptop PC that you know you're going to keep for a while and don't intend to upgrade the hardware on. The registration key is tied to the ID of your PC's hardware and the registered software will cease to work if you change the CPU for example, and they'll only allow a second re-registration, and that's it.
Trev does this mean there are bluetooth dongles available that are VCDS compatible? I am still using a cable but would love to get hold of a bluetooth dongle Tim
I'm not sure if Ross-Tech's software supports Bluetooth dongles but I'm guessing not (correct me if I'm wrong though) because they're heavy on supporting their own wired dongles. I do have a Bluetooth ODB dongle sat on the desk waiting for a project though...
would vcds lite allow me to check the timing of my mk3 tdi pump and activate the cruise control for example?
defo cruise not sure on timing, is it not mechanical pump on a mk3? its very useful even in shareware mode for reading and clearing codes.
The mk3 tdi uses an electronically controlled mechanical bosch ve pump collie...this is the reason why the cruise control only needs simple swithches and an ecu recode to get it working.
the cheap vag-com 409.1 usb cables are all you need for mk3 golfs, or vcds-lite which is basically same sw but updated to work on newer versions of windows. the full VCDS is only required for more modern VWs. pm me
Now up and running.... Still need to have a play....most interested in checking the pump timing....which measuring block do i need for this??
I got some hacked software with full access to all functions and matching lead off ebay for 50, the guy sometimes pops up for 1 day only every now and then, to avoid detection i guess. Not that i condone such things of course, i was of course not aware mines a vag 912 dual k & CAN lead.
Iv have a cloned lead as well as you say they come up from time to time I think I payed 28 quid for mine Dose everything the real one can The lead I have has vag 106 on it Some AntiVirus don't like the software
i bought the full hex/can lead a couple of years ago. expensive, but means it keep updating for more modern vag vehicles. I got a crafter van earlier this year and its been updated to cover that etc.
I have a fully legit Hex com lead (250 when i first bought it) but had to get a cloned CAN USB lead fully working version to look at the newer platform cars. These cloned versions are very useful, i wouldnt bother with 409.1. I'm able to get theses from a contact i have, any time.
For the money I've spent, I'm happy...my A3 tdi se, mk3 tdi gl and abf'd mk2 all communicate fine but I need to have a play to see what functions are enabled/disabled
I'll have a play and report back...I've probably already saved myself the cost of the lead by diagnosing the fact that the brake pedal switch on my mk3 was bringing on the glow plug light every now and then
A full version of VCDS lite will do the adaptions and bring up the tdi timing tool. Just go into measure blocks on the engine then click switch to basic settings and the TDI timing graph will come up. Select your engine type and it will all make sense.
i've just checked the timing using the tdi timing graph on the mk3 and it's reporting 'timing within spec but retarded' with a value between 29-31....I'm taking it that the best vaule for the timing is to be around 60?? Regarding adaptions, i'm going to have a go at adapting the EGR to not open anymore when time allows
