VCDS lite - help me please
Discussion in 'Vagcom / VCDS' started by Steve123, Jan 4, 2012.
  1. Steve123 Forum Member
    Calne
    Hi,
    Right I'm having trouble with vcds lite.
    I downloaded it last night and my new cable arrived today (it is only an eBay one but I only wanted to quickly check engine fault codes)
    I got it running, it found my interface in com3 everything was looking good. But I cant connect to a contoller for the engine section!
    It keeps coming up with 'NO RESPONE FROM CONTROLLER' the only ones I can do are my steering wheel, abs and instruments.
    Why is this happening? Its driving me crazy!!!!
    Anyone?
    Cheers
  2. MUSHY 16V
    aberdeen
    is it usb did it not come with software most do
  3. Matt82
    Matt82 Forum Addict
    GTI Scene
    So it can access abs controller etc but not engine controller?
  4. Steve123 Forum Member
    Calne
    Yh it's USB. And it came with software mate. I got it reading some stuff just not engine.
  5. Steve123 Forum Member
    Calne
    That's exactly it. I got access to a few things as said above but it doesn't find a controller for the engine.
    Really confused
  6. Matt82
    Matt82 Forum Addict
    GTI Scene
    I can't remember your previous thread but does the car run?
  7. Steve123 Forum Member
    Calne
    Yh it runs fine
  8. eightieshatches Forum Member
    Hertfordshire
    have you changed the baud rate in the settings as i had a mk4 golf with a similar problem?
    then when i checked on the ross tech site it suggested that.
    hope that helps.
  9. rubjonny
    is this a 96on mk3 golf, and if so can you read the immobiliser?
  10. Steve123 Forum Member
    Calne
    It's a mk4 golf
  11. rubjonny
    ok, can you talk to the dash?
    try shouting louder if not :lol:
  12. Steve123 Forum Member
    Calne
    The only thing that's happend is the abs light has flashed. But I thought the indicators were ment to flash when it was properly connected?
    Is there not something I can change in the settings of vcds to make it find the engine contoller?
    And shouting doesn't work. Called it every name under the sun last night lol
  13. Steve123 Forum Member
    Calne
    Is it true that an after market head unit can mess with vcds?
    I've read on other forums and searches that if you unplug the head unit it shoul allow vcds to work properly?
  14. Collie Forum Junkie
    Adlington Lancs
    yes unplug an aftermarket unit. i have had issues with my lead and headunits
  15. Danallkins
    Danallkins Forum Member
    Deal, Kent
    try disconnecting the car battery for a few min then reconnect and then connect vagcom and check again, the controllers sometimes need rebooting on the 98-99 golf.
  16. Steve123 Forum Member
    Calne
    Ive tried that mate, left it unplug for an hour but it didn't make a difference. I'll unplug the head unit when I finish work.
    Cheers guys
  17. Steve123 Forum Member
    Calne
    Unplug the head unit, still say no response from controller.
    Tried it in my mums golf mk4 and it worked straight away!!!
    What is wrong with my car?? :(
  18. Collie Forum Junkie
    Adlington Lancs
    does the led in the lead light up when plugged in. is there definatley power at you obd port?
  19. Steve123 Forum Member
    Calne
    Yh it lights up. Every thing worked fine in my mums golf.
    I even plugged the standard head unit and cd player to try it still nothing :(
    Really doing my head in now!
  20. MUSHY 16V
    aberdeen
    pull the fuse for the instrument cluster and try again
