Very strange start problem?
Discussion in 'Engines' started by gti_kev, Oct 12, 2005.
  1. gti_kev Forum Member
    Swansea - Wales
    This is still the same problem i have had for ages, a few topics on here about it.
    To recap - start from cold, car fires up and revs hit 1100rpm then drop to 350ish for about 10 secs and then returns to normal, leave for a further minute and she drives fine. once warm, starts up no problem all day long.
    Leave it over night and the same problem occurs, but (as i just found out)If i leave it all night, all day and night again parked, and start her up the following morning, she starts up no problem!
    So start her up after being parked for 12 hours - problem
    So start her up after being parked for 36 hours - No problem!!
    Any ideas? - is this something to do with the fuel pressure or something, loosing pressure when cooling down, but builds it self back up after 24 hour cold?
    So confused??
  2. ^neo^ Forum Junkie
    is it a K-jet?
  3. gti_kev Forum Member
    Swansea - Wales
    Yes mate! 16V
  4. ^neo^ Forum Junkie
    Fuel accumulator probably!
    Mine went all freaky like that, wouldnt start if you parked facing uphill in the end :lol:
    Theyre not cheap, hence why mine didnt get sorted!
  5. gti_kev Forum Member
    Swansea - Wales
    I had a feeling it was the accumulator - strange why the pressure builds back up after 30ish hours though?
  6. ^neo^ Forum Junkie
    Gravity i spose?! Mine went the same though.
    Have you changed the filter recently? May help it
  7. gti_kev Forum Member
    Swansea - Wales
    Changed the filter, did not help :(
    is there like a non return valve on the acumulator? or is it the whole unit that needs changing?
  8. gti_kev Forum Member
    Swansea - Wales
    Before i go out and get an accumulator is there anything else it could be? - lift pump? (thinking cheaper parts first :))
  9. rubjonny
    What happens if you prime the pump a few times before you try to start it?
    Edit: defo worth replacing the lift pump first, also its worth bearing in mind the 16v fuel pump components are the same as early 8v (i.e. K-Jet) in case you find any in your local scrappy ;)
    Edited by: rubjonny
  10. gti_kev Forum Member
    Swansea - Wales
    I have primed the pump 20 times and it's the same??
    o yeah forgeot to mention, when i start her and i get the problem when i try and rev her it's really stuttery/lumpy!
    btw - did you get that pic for yesterday of the power steering bracket thingy?
    Cheers
    Edited by: gti_kev
  11. gti_kev Forum Member
    Swansea - Wales
    Still having this problem! :(
    I have tested the accumulator and it holds pressure for over 2 hours over 3 bar (which is correct i have been told) priming builds the pressure back up to under 2 bar!
    I have also put new merc injectors in, but i am still having this problem, although once fired up now she does rev perfectly straight away!
    Any ideas?
  12. rubjonny
    is it better/worse with the WUR unplugged?
  13. gti_kev Forum Member
    Swansea - Wales
    It's exactlly the same!
  14. rubjonny
    hmm, knackered WUR or sensor for WUR?
  15. gti_kev Forum Member
    Swansea - Wales
    No, WUR is fine, i just did the stealth mod on my wur, and it works perfectly! pressures are perfect!
    Sorry i should have metioned that first :)
    I replaced all 3 sensors on the side of the head, maybe i got duff ones!
  16. rubjonny
    hmm, could try swapping the leads over as they're all the same on a 16v :)
  17. gti_kev Forum Member
    Swansea - Wales
    I'll try this again, but i am sure i have this before :)
  18. rubjonny
    perhaps the 5th injector is seeping out a little fuel when the system is at a high pressure, then stops when the pressure drops. The fuel then evaporates away if left long enough?
    Wild guess that!
  19. rubjonny
    Does it always start fine after 36 hours, or could it have been a one off? I assume you've done the obvious & replaced/swapped all the ignition system bits including the coil :)
  20. gti_kev Forum Member
    Swansea - Wales
    I think that was a one off to be honest! And i have replaced everything except the coil!
    Is there a test for this?
