hi my vr6 has a problem when starting from cold, it will idle fine for a few seconds then just die. after a few mins of driving the problem has gone, any ideas?
wow, large font that! i have had a similar problem....i've got no fault codes coming up so am presuming its the fuel pump (the loud whine from it is the reaosn i'm suspecting its that) best to get your fault codes checked first. if none come up, it could also be fule pump relay, ecu relay, or ig switch.
woops was pretty big! got no whinin' from the pump had that on my old mk II was. will get the codes checked cheers
