vr6 fuel pressure
Discussion in 'VR5, VR6 & Wx' started by sciroccogt, Feb 11, 2013.
  1. sciroccogt Forum Member
    Hi peeps
    Can anyone tell me what the fuel pressure should be am going to fit a adjustable fuel reg with other mods
    Thanks
  2. benthejettaman Forum Member
    some where in the uk
    obd1 or 2? they are different
  3. sciroccogt Forum Member
    Obd2 mate if I raise it a little will it be better for performance
  4. luacgt1
    luacgt1 Forum Member
    wolverhampton
    Hi, standard pressure on the obd2 cars should be 3 bar.
    with regards to the adjustable regulator usually with most cars a leaner mixture will make more power (there is a point where it will had adverse effects too and or melt your pistons) it seems to be a common misconception that a car will be faster because you put more fuel in the cylinders. i would consider leaning it slightly, assuming the car will still cold start and idle correctly. However I do recommend setting the regulator up whilst on a rolling road/hub dyno.
    About 12 months ago i ran a well modded VR6 on our chassis dyno at work and it made around 194bhp @ the flywheel (this car was OBD1 with an aftermarket fuel regulator set to standard pressure which i forget now). Anyway to cut a long story short i backed the fuel reg off 1 turn and low and behold 210bhp @ the flywheel.
    So ideally set you new reg to the standard pressure settin, then get it setup for power on a rolling road or hub dyno.:thumbup:]
    Cheers
    Jay
  5. sciroccogt Forum Member
    Many thanks mate will do
  6. Adey Forum Member
    What did you do with the standard pressure reg?
  7. mk2redvr6 Forum Member
    I may still have it in my box of tricks
  8. Adey Forum Member
    I meant how did you go about bypassing or removing it?
  9. mk2redvr6 Forum Member
    Ah sorry brought a blanking Reg a
    For about 15 mate
