VR6 prototype in Mk2 Golf
Discussion in 'VR5, VR6 & Wx' started by Rallye, Dec 16, 2003.
  1. rubjonny
    i assumed syncro/rallye chassis design would have come from the corrado development side of things? but I don't know as I never worked for VW :lol:
  2. chopperoli Forum Member
    Scirocco Mk1
    Judging by the caption in the top photo, the 4wd system may have been developed for the Corrado first.
    I don't know if it mentions it here (cos it's all in German which I can only decipher basic info from) but it's a huge document all about the development of the Scirocco from the very earliest prototypes right up to the new 2008 Scirocco, including Corrado. Worth a look if only for the Junior Cup Scirocco. Seems to be mainly chassis/body design related but i'm sure you chaps would still be interested ;)
  3. Riley
    Riley Forum Addict
    Burnley/Lancs
    I do believe a 4 wheel drive corrado was in the pipeline?
    Obviously the lack of corrado sales didn't help with those plans[8(]
    Should have been rwd anyway![:x] :lol:
    Neil.
  4. DarrenH Forum Member
    Northeast Kent
    i've got an old mag from 1988 called "performance car", i bought it for astra gte content, but the cover car is a concept called vw "student" which is similar in size to a cinquicento, used mk2 polo runnng gear and bares a striking resemblance to the latter day lupo.
    also inside it has features on the twin engined 16v scirroco "bi-motor", also the jetta IRVW3, 1800 supercharged with air suspension like citroens. it lowers itself above 60mph for better aerodynamics and handling !!
    PhatVR6 mentioned somewhere on here that the Corrado had a couple of pick up points or Syncro/Rallye style panelling under the back which almost confirms it.
  6. RallyeVR6
    RallyeVR6 Forum Junkie
    There is also a Convertable Corrado that VW made test cars for. That would have been......interesting.
  7. PhatVR6 Forum Junkie
    yes, there are cutouts in the rear arch which are only ther to clear the brake lines on a syncro rear axle.
    it's early passats that have the smae underpinnings as the corrado and g60 shells. golf syncro's also have them, along with the big tunnel, whihc passats, g60s and golf syncro's share.
    just tot he right of the hole in the leg
    ignore the other dent in the middle, that was from the driveshaft rubbing (no rear arb, ahem)
    Another pic I've stumbled over - I don't think this an Oettinger 2000E, judging from a pic I have of a 2000E manifold, but it's got 6 inlets [:s] In an early grille Mk2?
  9. romaingirardlamamy
    romaingirardlamamy Forum Member
    london
    Is it me or it s an early vr6?
    Look closer 6 injectors
    And what look like 6 HT leads
    And regarding the head in picture above
    Is pretty different then the oettinger head
    Exhaust cam driven by the belt
    then inlet cam driven by exhaust via gears at the other end off the cam
    The oettinger head is
    The Inlet driven by the belt
    Then exhaust driven by the inlet via gears too on the same side (I believe that s better because there is less flex)
    The curious thing is that oettinger had the 16 valves head way before the factory
    Then came the 20 valves turbo which too was way before the factory
    Did you guys know that oettinger created a 6 cylinder engine (flat 6) for Vdubs van
    They also fitted bugs engine with splited needles bearing instead of main and con rods shell bearing,
    I read this thing was capable of crazy high revs
    I have been told by an ex engineer from oettinger that even when vw had their 16 valves head ready
    The factory was still using the oettinger head because it was better then the VW
    Then they developed it and used the vw head
    Yes, I agree, surely it has to be? Wierd. Just found the picture on my computer, I'll have saved it down or scanned it at some point [:$]
  11. mk1. Forum Junkie
    that vr6 mk2 is posted elsewere on the forum from a while back.
  12. A.N. Other Banned after significant club disruption Dec 5th 2
    Thanks - I guessed I'd found it somewhere! :thumbup:
  13. Toyotec
    That looks like some sort of 6 cylinder. The plugs leads seemed looked staggered.
    Any more information.
  14. tobyk
    tobyk Forum Member
    Aberdeenshire
    Pre production VR6?
    If mk1. has any recollection of the original thread? Getting a bit sidetracked on this one from the thread topic, but interesting info all the same :thumbup:
  16. mk1. Forum Junkie
  17. 20v_jimmy Forum Member
    Bristol
    Yes i believe this is indeed a pre production vr6. There is or was some info about it over on Vortex somewhere.
    (edit; too slow)
  18. shaz8389
    shaz8389 Forum Junkie
    As per VW Vortex legend it was the prototype VR6.
  19. 3hirty8ight Forum Member
    Pre-production VR6.. A diesel. As that was the VR6's intended first design was to be a diesel. (Not that this is a diesel) but just saying!..
  20. Neal H Forum Member
    Look at the position of the HT leads too, completely different to the production versions...
