vr6 stutters
Discussion in 'VR5, VR6 & Wx' started by AndrewF, Jun 28, 2004.
  1. AndrewF Forum Addict
    Milton Keynes
    mkIII vr6...
    done a couple of modeartely long journeys and after a while on the motorway, the car starst stuttering a little bit. usually when at about 70mph. its getting more often as well. tends to do it at lower rpm's.
    any ideas?
  2. TheSecondComing Forum Addict
    Speech therapist?
  3. AndrewF Forum Addict
    Milton Keynes
    thanks, i'll try that! :lol:
  4. TheSecondComing Forum Addict
    Sorry, I had to....... [:$] :lol:
  5. TheSecondComing Forum Addict
    Thought I'd better bump it to the top, as I killed it.....
  6. AndrewF Forum Addict
    Milton Keynes
    how nice of you mr. tsc
    i'll add some bits.
    it never stuttered, but hadn't been idling when cold. got fault codes checked and it came up with engine speed sensor (presume the car wasn't running when codes checked), speedo sensor intermittant (as is the function of my speedo, so know about that), and ISV not reaching adaption speed (whatever that is).
    he suggested cleaning the ISV with carb cleaner. so did that. then went on a reasonably long journey down to buckmore park. was fine till almost home then stuttered three times.
    so, cleaned ISV again. then went to donnginton park, stuttered loads both ways. seemed to be getting worse.
  7. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    Cam sensor, or possible some thing else with a ignition, coil pack/leads?
    you realy need to get a VAG scan tool plugged in, to help work out the problem
  8. AndrewF Forum Addict
    Milton Keynes
    could be i've tugged out a lead moving the cover to get to the ISV i suppose.
    be pretty unlucky having a new prob/code the day after i got them checked wouldn't it.
  9. GVK
    Had similar prob with V6 Galaxy, plug leads sorted it.
    Does it ever drop off a cylinder under acceleration ACF?
  10. AndrewF Forum Addict
    Milton Keynes
    it may well be doing that gary. (not as obvious with a 6 cyl as it is with a 4cyl)
