Hello all Not posted in a while. Got a 2002 1.8T Bora and the alarm has just started to go off, but of coarse this happens at 12.30am and them again at 3am this morning.... I had to leave the drivers side unlocked in the end so i could get some sleep along with the neighbours All very random and for no external reason as far as i can tell. Looked for fault codes today and one has come up... 1 Fault Found: 00930 - Locking Module for Central Locking: Rear Left (F222) 27-00 - Implausible Signal Guess this could be setting the alarm off, what do you think? Ive cleared the code so see if it comes back... Ive seen the dry joint problem that people get on the Passat's that can through this error. Anyone know where the log is for what set the alarm off with vagcom? Can i switch the alarm sounder off completey by adaption with vagcom? Only setting i found were to do with the indicator flashing, something to do with the key and change the type of alarm sound depending on country. No sounder disable in that module anyway. Failing that i quite happy to disconnect the sounder if thats possible, anyone know where that might be on the car?? Cheers Gonz
