which 3 dials can i put in the little slots where my radio once sat? gotta be eeeeeasy to wire up aswell or an in depth step by step idiot guide on how to do it... volts a clock? and.... also, ford crapi's had lots of little dials, would any dials fit in any car? or is that a silly question
all type of dials would fit if connected to the right place. If you want a easy one the why not fit an AMPs one (or Ammeter) along with the voltage meter. It would show you how much current is flowing in or out of the battery while the volts just shows the current level of you battery. Oil pressure might be useful also (not sure how this links up tho). What about an external temperature meter. Old audi quattros had lots of dials too. Some ideas....
i shall have a looky on monday/tuesday amps, that in series or parralel, you'd have thought id have learnt SOMETHING from colege.... maybe if i was awake more of the time
amps -series volts - paralel oil pressure? oil temp? water temp? clock? boost? plenty of dials can be put in.
Amps, are a poop to fit. You have to send all the battery voltage throught the dash to the gauge, so thats a fappin' huge wire to the dial and back to the alt circuit.
