What is this for?
Discussion in 'Mk2' started by Gavsdad, Jul 12, 2023.
  1. Gavsdad
    Gavsdad Paid Member Paid Member
    Hetton Le Hole
    Found this on throttle body when engine out of car so took pic couldn’t see it with engine in place.the nipple looks like it has had a rubber tube fitted to it and snapped off. After engine put back in and engine running there seems to be a vacuum on it, the mfd display is working ok with tube feeding it in place near to servo pipe. Any ideas?
    It's one of the vac line take offs, sometimes used to feed the mfa for fuel economy, or else blocked off.
  3. rubjonny
    that would be used if you have carbon canister setup, but you dont so it should be blanked ;)
