I've got the 'KR' engine and I'm stuck on what sender goes where and what wire goes on what switch. Under the dizzy where a water heater pipe is fed from you have 4x sender. One of which has a brown plug and can't go anywhere else other then the bottom right hole in the head. But the other 3 I'm stuck one what one goes in what hole, but mainly what colour wire goes on what sender, Really appriciate the help if possible as I can't find this in the books I have Cheers
doesnt really matter they are all temp senders and should have the same sender rating. 2 are into the water jacket & 1 into the block - so you can alternate about red/green = ISV blue/white = ECU red/yellow = dash temp gauge
2x in the water jacket and 1x in the block??? The ones I have all go into the water jacket in the head, none go into the block from what I can see??
block was maybe the wrong word oops yes, 3 senders around the coolant inlet pipe - if you where to screw the 3 out, you'll find two pss coolant, the other one wont as its into the head & not the water jacket dont ask which one as i can never remember!
