Whats this part for?
Discussion in 'Carburettor' started by ilg2064, Nov 10, 2007.
  1. ilg2064 New Member
    Puebla, Puebla, MEXICO
    Hello again, well...Ive got my car from my dad and Im trying to keep it in good shape; and now I found this:
    It is disconnected and I have no idea what it is for, and dunno if still in good shape even if I reconnected.
    Anyone?
    ...sorry if my english is not good enough.
  2. golfmanuk Forum Member
    Coventry
    best thing you could do mate is get a part num of it, put on here if no body knows by looking at it
  3. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    It is a vacuum reservoir. I'm not sure what carburettor you have (can you take a photo with airbox removed?) but on the Pierburg 2e2 (and 2e3 also, maybe) it connects to the choke pulldown unit, allowing a slow, controlled transition from the first stage of pulldown to the second stage over a few seconds. That is, an automatic partial opening of the choke flap as engine vacuum develops on first starting from cold.
    What engine size is it?
  4. ilg2064 New Member
    I have a bocar, didnt hear of it in the forums but thats what I have; Ill take some pics later.
  5. ilg2064 New Member
    Pics of the carb:
  6. Sciroccotune Forum Member
    is it an auto? just not familiar with the valve thing on the left of the carb.
  7. ilg2064 New Member
    It is manual (hope I understand right->auto=automatic transmission)
  8. rubjonny
    thats deffo a 2e2, but it looks like its off another car, a beemer or ford perhaps? Never seen that cylinder on the left there, thats where the 3/4 point unit is supposed to go...
    If the car runs ok I'd leave it as its :)
  9. EZ_Pete
    Never seen one quite like that, looks to have a very 'Pierburgy' style. A bit of carb cleaner looks like it might be good. If it starts OK from cold, you could forget about or remove that green ball, as long as there are isn't a vacuum hose lying around leaking air that should be plugged in to it. If there is a vacuum hose that looks like it would reach there, plug it in and see what happens.
