Stay away from this garage they are cowboys. They have dodgy practices such as replacing only 1 shock absorber on an axle. They are very pleasant on the surface until you don't agree with you. Just a few more examples, they failed to diagnose a throttle valve switch being faulty from a simple idle fault. And they fitted an exhaust downpipe, failing to notice that they fitted a sealing ring too big which caused the downpipe to rub on the steering rack. A car was taken into them with what turned out to be a loose clutch cable, causing the clutch bearing too squeal, they said this was worn water pump mounts? no car even has water pump mounts as the pump is bolted to straight to the block. The list goes on and on. I have had a few years experience of this garage. BE WARNED STAY AWAY.
