Wheels stuck on!?!
Discussion in 'Mk2' started by turnipmuncher, Jul 15, 2010.
  1. turnipmuncher Forum Member
    Had the bbs rm's epoxy coated everywhere so removed the excess on the bolt face before bolting them up. The rears came off after being on the car a week, but the fronts are stuck on solid. Have had a few tugs (easy) trying to get them off with no luck.
    Any top tips for removal dubbers?
  2. nhoj62
    nhoj62 Forum Member
    nailsea
    try hitting the tyre with a 2"x4" to get the wheel to pop off the hub
  3. EZ does it Forum Member
    Coventry
    Hit the wheel from behind with a rubber mallet a bit at a time, turning it while you do, should work off bit by bit.
  4. neil kaye Forum Junkie
    england
    ^^x2 the grease them on the refit
  5. turnipmuncher Forum Member
    Definitely!
  6. afbiker02
    Bury St. Edmunds
  7. Mike_H Forum Addict
    I've had wheels stuck on so badly (G60 steels - rusted on) that I've had to undo the wheel bolts a few turns and take it for a slow drive, throwing the car from side to side. If they still don't budge, try a handbrake turn.
    I tried the hammer and lump of wood methods, but all I was doing was pulling the car off the stands.
  8. MK1G20VT Forum Member
    You need a dead blow hammer. These have what looks like small bb shot in the head and gives it more impact when you hit something. Machine mart do them, we use them for work and they work a treat. :thumbup:
  9. Matt82
    Matt82 Forum Addict
    GTI Scene
    i use the 2x4 approach but on the inner rim of the wheel
  10. Ben S
    Ben S Forum Junkie
    Essex
    I use a KUNG-FU KICKā„¢
    though if your kung fu is weak, use a rubber mallet
  11. Matt82
    Matt82 Forum Addict
    GTI Scene
    if you dont have a mallet
    stare it down
  12. turnipmuncher Forum Member
    Did consider this method...
  13. Phil. Forum Junkie
    Northern Ireland
    Also known as the Chuck Norris method. :lol:
  14. Zaphod
    Zaphod Forum Member
    Wantage
    Works every time for me!, just don't undo them too much!
  15. Ben S
    Ben S Forum Junkie
    Essex
    If chuck norris roundhouse kicked your wheel, all wheels within a 1 mile radius would fall off
  16. turnipmuncher Forum Member
    Worked a treat - the bolts were a couple of rotations from being tight & worked loose after 100 meters. You can hear them when they break free.
