As in title, going to finally fit the lambda, but looking at it, the cable from it will only allow it to be fitted to one of the two pipes from my downpipe, is this ok? if not, can i extend the wires to fit where it joins to 1 pipe? Car is running fine at the moment on 3.2 digi, abf exhaust manifold and 8v downpipe to a stainless system. Thanks, G
You can lengthen the wires. It would be better if you put the lambda probe where the downpipes merge into one just before the join to your main exhaust. It will give a more consistant reading of all the cylinders there. Try and fit it so that it is pointing slightly down at about the 2 o clock position as this will limit the potential for it to hold moisture in the probe end whilst the car warms up.
