Looking to take my mk2 back to small bumper as the sills are stupidly clean now I want to leave my sills exposed and not use viynl tape or sill trims, so just require arch trims but you have 3 different ones listed on site which ones do I require ?
Hi Rich, You could run these, the early spec arches (84-87) -originally run with the "stick on" side mouldings and vinyl on the sills. Alternatively you could use these, the mid spec 88-92, non 90 spec arches. These dont have plastic side skirt take offs, but do require you to run the thicker style clip in side mouldings. Let me know your preference and i'll pop the links up for a full set Andy
Hi Rich, Here you go! Front left http://www.vwheritage.com/vw_spares...7-191853717_act_shop.product_pID_58896856.htm Front right http://www.vwheritage.com/vw_spares...7-191853718_act_shop.product_pID_58897410.htm Rear left http://www.vwheritage.com/vw_spares...t-191853817_act_shop.product_pID_58897710.htm Rear right http://www.vwheritage.com/vw_spares...t-191853818_act_shop.product_pID_58898419.htm These are cheap at 11 each, but they are repro - so the quality won't be up to the standard of Genuine, sadly genuine early arches are no longer available. There are a couple of these out of stock, they will be about 3 weeks to come in. Hope that helps Andy
