I am hoping to turbo a KR, i have 2x9A engines, 1xKR engine and S2 pistons and S2 rods. which combination of crank/rod/pistons will give the best CR? i know the S2 pistons are used, but with which rods/crank? this will go into the KR block. i have searched this and maybe missed it, but didnt find an answer. 9A crank, KR rods and S2 pistons, what CR would i get roughly? (if it would work at all!) KR crank, rods and S2 pistons, what would i get roughly? would you recommend soucing different rods? 2E for example? many thanks in anticipation Rick
S2 rods = KR rods. S2 81mm pistons would suit KR bore but with lower CR, ideal for a turbo or supercharged application. 9A is a 1984cc engine with 82.5mm pistons. 2E rods for a tall block i.e. ABF, 2E with 21mm piston pin and are not suitable to you.
