So, I can get either for the same price, so it's just a matter of which? Both can take the G60 flywheel, and VR6 clutch, correct? It's for a Audi TT 225hp engine. Thanks Edited by: HidRo
I'm sure the Golf Mk3 16v gearbox has better ratios for the conversion (so Designadubs told me). Vr6 clutch should be fine
From all the research I've done, there are some G60 gearboxes that have longer ratios, and at 7000RPM, it would be at 270km/h the GTI one will be at 260km/h i guess... Btw, which starter motor I'll have to use? The KR one will bolt up on a GTI III 16V gearbox with the G60 flywheel?? Do you happen to know what it the rev-limit on the TT 225hp?
The mk3 16V flywheel, I CAN'T get. The starter motor, I don't know, but I'll see. But the G60 flywheel is the same as the mk3 16V one, right? Or am I wrong? I'm such a n00b! the 2Y starter motor will not bolt up?
I believe the G60 and mk3 16v flywheels should be the same. The 020 (mk2 16v) starter motor won't fit the 02A (mk3 16v) box.
