Which spark plugs for a Mk2 16v
Discussion in '16-valve' started by jedi, Aug 31, 2012.
  1. jedi Forum Member
    Hi does anyone have any recommendations for spark plugs I've always used bosch super 4's on my previous two 16v's apparently these tend to cause arcing inside the dizzy cap which i have to admit I did used to get, I've currently got Bosch superplus plug's in at the moment but even after checking the gap's the car has never felt quite right since fitting them, are Iridium plugs worth the outlay as ideally I don't want to fork out 40 odd quid on spark plugs
  2. jamesa Forum Junkie
    Abz
    When running a 9A (Corrado 16v) I used the Bosch Super4 without issue, then changed to NGK BKUR 7ET again without issue.
    The NGK site below lists the BCP 7ET as standard for the KR 16v and BKR 7EIX Iridium as an upgrade.
    I buy my (non VW) Iridium plugs from Driven2automotive as they are half the price of some others, see link below for yours ... 27.44 delivered.
    See also `other` link for price comparison to standard plug and Iridium.
    I was recommended NGK by a guy that worked with Champion
    Apologies for the `essay` but ... use Iridium !!!
    http://www.ngkpartfinder.co.uk/car_...model=GOLF%20MK2%20%2884--%3E91%29&engine=1.8
    http://www.driven2automotive.com/se...ay=desc&search_query=bkr7eix&submit_search=OK
    http://www.gsparkplug.com/shop/ngk-bcp7et.html
  3. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    What? I'd love to hear the theory behind that. Sounds very made up to me. lol
    Probably from someone who thinks a four-electrode plug gives four sparks.
  4. 3hirty8ight Forum Member
    I run NGK BKUR 7ET in my race car.. They're are more than adequate! Iridiums are overkill IMO..
  5. Brookster
    M1 J40
    I use BKR 7EIX Iridium all the time , and up the to 8's when running on the NOS
    standard beru z52 or whatever the equivalent std fit bosch or ngk is all you need, no need to mess about with super 4s or other 'upgraded' plugs they wont offer any benefit
