my mk2 golf gti 16v is kicking alot of white smoke out of exhaust pipe wen i first start her up, a friend thinks it just damp causing it 7 nothing too worry about? should i be concerned/
if it stops soon after firing up dont worry about it. one of the byproducts of combustion is water so you will get a bit of moisture in the exhaust system. any moisture will be more obvious on a cold morning too. if the smoke is blue it could be oil leakage into the bores from worn stem seals though
thanks for advise john appriciate itit only pumps out white smoke wen i first start her, soon goes wen driving & warms. cheers john, col.
