Who can build my 16v race engine? Recommendations
Discussion in '16-valve' started by djdubs, Dec 17, 2012.
  1. djdubs Forum Member
    I'm looking for someone who can build up my 16v race spec engine. I could probably do it myself if I put my mind to it but after spending a lot on all the right parts I'd rather find someone with prior experience/knowledge of such builds. I have most of the parts ready to assemble Inc all new gaskets, fittings, etc and machined/lightened/balanced parts by Hotgolf.. Brief spec as follows..
    9A bottom end bored out to accept wossners
    knife edged/balanced crank
    lightended intermediate shaft
    wossner high compression forged pistons
    INA H beam rods
    ARP head studs
    All new bearings, etc
    New baffled sump
    Neuspeed windage tray
    (need exhaust manifold)
    ABF cylinder head
    Ported & polished
    Injector ports tig welded up for ITB's
    3 angle valve job
    Machined for clearance of high comp pistons
    New hydraulic lifters & valves
    Newman 272 cams
    (unsure at this stage whether to use these cams or go for something wilder with solid lifters.. Engine is going into a wide tracked Mk1 Golf track car)
    New 45mm throttle bodies
    (need inlet manifold)
    Omex engine management system & wiring loom
    .. I'm based in Lancashire so someone local would be ideal but I'm open to suggestions. Anyone recommend someone who can make a good job of building this sort of thing? A bit of cash for the new year!! ;)
    Thanks
  2. mitlom
    mitlom Forum Member
    Ripley, Derbyshire
    I would recommend Mr Hillclimber....but then I am biased as he's building me an 8V currently ;)
  3. ian-speedy Forum Member
    Me too , my engine was built by him , and is 249hp with good torque from low down , it goes very well
  4. tones61
    tones61 Forum Member
    ~ MOT TESTING ~ plymouth
    plus ONE :thumbup:;):thumbup:;):thumbup:
  5. djdubs Forum Member
    Thanks for all the replies. I've spoken to Jason now and had a good chat.. nice guy. I hope to get it on with in the new year but probably going to go with a solid lifter head and wilder cams to his spec.
  6. bigbenbird Forum Member
    Alberta, Canada
    Out of interest what would the labour costs be on a build like this?
    BBB
  7. brutalmk2-16v Forum Member
    Manchester
    Does this happen to be a rally engine?
