Why did i ever change the Cam Belt
Discussion in '8-valve' started by streethawk999, Mar 9, 2010.
  1. streethawk999 New Member
    winsford cheshire
    Guys
    I changed my cam belt on my 1985 1.8 8v, but had problems trying to line the marks up, managed to get pullies to line up and it turned over but now car wont start, alll i can hear is a clicking noise.
    Have checked the battery and its full, took the starter off and shorted it turns fine.
    I am wondering if i have replaced one of the pullies upside down???
    Any help is welcome been trying to fix for 3 days
    Thanks
  2. Matt82
    Matt82 Forum Addict
    GTI Scene
    can you turn the engine over by hand?
    id disconnect your ecu whilst you do this incase you fry it
  3. streethawk999 New Member
    winsford cheshire
    yeah can turn engine over by hand if i take plug out, its K-jet so no ecu
    Ta
  4. Matt82
    Matt82 Forum Addict
    GTI Scene
    fantastic.
    well it sounds more like an issue with the starter wiring. the mk2s have a really common issue with the earth that goes to the gearbox. clean up the contacts, i went as far as to add another earth onto the starter itself when mine refused to turn over with a perfectly good battery
  5. streethawk999 New Member
    winsford cheshire
    yeah thats what i thought am going to try contacts when i get home ta
  6. pigbladder Forum Addict
    cambridge , uk
    maybe double check all those timing marks just to be safe...easier to spend another 20 mins than louse it up
  7. RIP-MK3 Forum Addict
    sunbury on thames
    ^^ was just thinking that. We also ran another earth just to be sure to be sure
  8. streethawk999 New Member
    winsford cheshire
    Thanks for the help
    Here is where i am now
    Engine were turn over very sluggish and stop
    then wont turn again
    removed plugs and engine spins free
    Think i have the crankshaft pulley 180deg out, is this possible ??
    I noticed that when i refitted the pulley the little locking key could fit in two places ???
  9. pigbladder Forum Addict
    cambridge , uk
    yeah sounds like cam /ign timing
    go over it all until you are 100% sure
    if you use the flywheel mark then its foolproof
  10. streethawk999 New Member
    winsford cheshire
    i have been looking for the mark on the flywheel but cant find one, going cross eyed looking through the whole........
    Think i might of found a very faint O as a mark, Is this TDC
    Ta
    Thanks Everyone who has replied so far
  11. pigbladder Forum Addict
    cambridge , uk
    yeh it is a 0 shove something down #1 piston to confirm its at the top , the mark should be visible then
    once the belt is on right...check where the rotor arm is pointing
  12. Mike_H Forum Addict
    Bump - did you get anywhere with this? Sounds like it's probably cam timing, but if the ignition timing is way too far advanced it can make an engine harder to turn over too.
