Will G60 injectors,exhaust manifold and cam fit a PB 8V??
Discussion in '8-valve' started by PaudieG60, Dec 5, 2011.
  1. PaudieG60 Forum Member
    Ireland
    I have a few G60 parts {PG} lying around and a fella with a 8v was asking me will any of the above fit his engine and if they did was there any point in fitting them??
    Im thinking the injectors and exhaust manifold will fit,not sure if theres any point in fitting them but no idea if the cam will work with his engine?
    Any ideas??
  2. milesmk2 Forum Member
    Cam - cant tell you
    exhaust manifold - the only diffrence is that the G60 one will have a lambda probe hole
    Injectors - they are a larger capacity and the ECU will have to be tweeked as far as i know.
  3. dogzila Forum Member
    G60 cam overlap should be 0
  4. scruffydubber Paid Member Paid Member
    Dubhampton
    I would have thought the G60 cam would reduce performance quite a bit.
  5. PaudieG60 Forum Member
    Ireland
    Thanks for the replys lads!
    I can tell him the cam is no good to him so.
    Dose the g60 exhaust mani have a bigger diameter than the 8v?
    cam no, too lame for n/a
    injectors no, too much fuel for n/a
    fuel rail & fpr yes they're the same
    exhaust yes
    lambda hole is in the cat or maybe downpipe. extra hole in manifold is for co sniffer ;)
  7. PaudieG60 Forum Member
    Ireland
    Cheers John,just spotted this now!
    Is the exhaust manifold diameter the same on both does anyone know?
  8. rubjonny
    manifold is same at the gasket ends so it bolts up to g60, 8v and 16v downpipes no problem, and any 1.6-1.8 8v petrol head (not sure on diesel)
    i think the manifold may be slightly different shape, but not 100%
