hey there peeps just a quick question is there a way to get me screen out without breakin it as wanna sort rust spots under rubber i have been told to sit on both front seats with my feet half way down and a quarter in from each side then just push ??? any help apreciated daz
id ease the rubber over the lip with a large screwdriver or something hoofing it with your feet will cause any chips to spread and crack or cut the rubber and get a scrapyard rubber to replace it
as above, only sure way is to slice the rubber with a sharp stanley knife. if you fancy doing it the hard way then get an assistant (sitting in the passenger's seat) to apply firm and steady pressure to the top right of the screen from the inside whilst you gently manouver the rubber seal over the metal lip with a large screwdriver. Gradually move rightwards across the top of the screen. Your assistant should need to apply less and less pressure as you go (common sense required) once the top is out then press the sides out and lift free of the wipers. reverse is done using a piece of string and silicon lubricant not a job to be lightly undertaken as chances of a breakage are fair to middling, especially is its a first attempt. whilst you're there make sure to do a good job as I did this work only two years ago and the rust is back :-(
cheers peeps i think i will go for the safe option and just cut the rubber im assumin to get it back in i just but rubber in and use the srting???? cheers daz
