Hi just wondering what sealant the guys at auto windscreens use? I have a leaky rear quarter seal, I know they dont use Silicon anyways, cheers
See Dintrol in left menu, Page 2, then bottom of page Frost Dinitrol windscreen sealant Edited by: rocco
Should you be using sealant on that ? Was it a new seal which is on it as that would cause a leak if it wasn`t and make sure it is fitted right also.I had similar problem which was sorted by doing this.
Cheers the problem was it was rotten underneath on the lip slightly, therefore I built it up with Fibre glass, and refitted. I can't justify spending nearly fourty quid for a new seal as a result so I got one from a scrappy so it really needs a sealant, cheers
