runnin qpeng mbe ecu but seem to be gettin no power from ecu to fuel pump, injectors or coil packs, an cant work out if i get everythin connected correctly. i have voltage at the black 12v switched wire, can any one suggest anythin, its becomin very frustratin now
are you using the fuel pump relay to power up the the coils injectors ect if so check you have a tach signal at the relay
only wire i usin for fuel pump is the red an yellow in scuttle, does that need earthed, i assume the signal will come from tach connection
