Does anyone have the part number for the sleeve that sits inside of the wishbone rear bush wrapped around the bolt. I've checked vagcat but it isn't even pictured for Mk3. Checking for Mk2 it's pictured but doesn't actually have a part number reference.
191407190A is what the mk2 uses they did away with it on the mk3 and use a different bolt or the subframe has a bit to center the bush think its the latter as the same bolt is listed for both
From what i remember it's a C shaped bit welded to the subframe that centers the bush sometimes people remove them while fitting poly bushes though good kits have a plate that covers it
