is it type of bolt i have never used them but can see it could work is the bore of the wheel the same or are you going to have to use spigot rings as well i would not like to use both wobble bolts and spigot rings http://www.serpentautosport.com/wheel_accessories_lugs.htm
why? spigot rings are essential regardless what wheel you fit, they ensure correct alignment and reduce the stress on the bolts if you fit a wheel with wobble bolts and without spigots, you really are asking for trouble. at best it`ll drive like a dog and at worst it`ll put someone in hospital.
