Won't start after head gasket changed
Discussion in '8-valve' started by Jeebz, Sep 25, 2011.
  1. Jeebz New Member
    A couple weeks ago the head gasket went on the motorway.
    I finally got round to changing it by now i can't get it to start again.
    Its had a new gasket, head bolts and belt. And ive timed it up using, flywheel mark (also put it at tdc @ #1 when head was off), inside mark on cam and on intermediate shaft. It then had a new battery and there is juice going down the leads (decided it would be a good idea to touch them to check), and there is fuel going to and coming out of the carb. Starting to get a bit frustrated now as I do need it back on the road.
    Its a 1.8 carb.
    any advice would be much appreciated,
  2. Joesoap Forum Member
    Just check when you have her all timed up that the lead the rotor arm is pointing to is number 1
    (Which is on the cam sprocket side) and should also be pointing to a nick on the distrubitor body or close to it.
    Also your TDC mark on you flywheel is the faint dot indent
    next to the large clear V nick.
    Inside mark on cam sprocket should be inline with front of rocker cover lip
  3. Jeebz New Member
    Rotor arm is pointing to 1 and its lined up with the tdc mark on the flywheel. It just turns and turns by doesn't catch.
  4. dan_gti2004 Forum Member
    Newbury
    Did you get the head skimmed? It might be warped. Do a compression test.
  5. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    Just to be thorough - and reiterating what volksport has asked already - can you confirm that the flywheel TDC mark you're using looks like the yellow-ringed dot in this pic?:
    Not the red-ringed v-notch in this one:
  6. Jeebz New Member
    its not the v notch its the one to the right of it. i don't have a compression testing kit but i have placed a large square along the bottom of the head and shone a torch down the seem and no light came through. any tips on compression testing without a kit? all i have done is place my thumb over the spark plug hole and check for pressure.
  7. milesmk2 Forum Member
    Where are you from?
  8. Jeebz New Member
    south wales, but im off to uni on tuesday evening, i might tow it to a mates garage if i don't get anywhere with it tomorrow morning.
  9. milesmk2 Forum Member
    Where in south wales? I may be able to help!
  10. Jeebz New Member
    Usk near newport
  11. milesmk2 Forum Member
    I live in Caldicot. Pm me your number and i'll ring you.
