Would you buy this VR6 engine
Discussion in 'VR5, VR6 & Wx' started by buck4229, Aug 16, 2004.
  1. buck4229 Forum Member
  2. S1MMA Forum Member
    depends on the price! cant be worth that much with the history can it? Gotta be worth trying if you can get it dirt cheap?
  3. Funkyfin2000 Forum Addict
    Stafford, United Kingdom
    be worth pennies....
  4. hayesey Forum Junkie
    Bahamas
    depends if the pistons have been damaged by valves hitting them I'd have thought. If you could get it dirt cheap & it's just a case of replacing some valves & timing chains then it might be worth it.
    Don't bid on it without going to see it first though.
  5. MarkGolf Forum Member
    Zimbabwe
    no way
  6. martyn_16v Forum Junkie
    behind the sofa
    Very big paperweight.
  7. Rahul Forum Junkie
    blimey, you gotta wonder how badly looked after the engine was for the chain to break! jumping teeth maybe but breaking! [:s]
    Are they duplex or single chains?
  8. Mikedav Forum Member
    Reserve met at 91. Surely its worth a hundred quid or so?
